Is ChromeCasting to HT-NT5 HiRes @ 96k/24bit ?
ProJules
I am sending via ChromeCast HiRes 96k/24bit audio streamed from Qobuz.
Does the ChromeCast integration on the HT-NT5 operate at HiRes (96k/24)
(BTW I tried connecting a hardare ChromeCast Audio - via optical tos link to the HT-NT5 optical (TV)  input and it was silent with 96k signal, it would only play audio at the lower 44.1k sample rate)
Thank you
6 REPLIES 6
ProJules
One problem,
It seems that GoogleCast isnt possible with surround speakers running.
So thats no good for 5.1 audio...
Unless I have that wrong?
ProJules
I bought a Chromecast Audio which outputs 96k 24bit hi res signal
But it's not being accepted by the HT-NT5 optical input.
44.1k k Redbook audio plays but when is send hires music signal (96k 24bi) to the chromecast audio there is no sound
Can you help me troubleshoot please?
What hi res sample rates does the HT-NT5 accept?
And what inputs does it accept it on?
Does it accept Multichannel (5.1) audio via optical?
Does it accept Multichannel (5.1) audio via HDMI?
Please confirm / clarify the HT-NT5 HiRes connectivity options
Thank you.
ProJules
And please confirm thr maximum sample rates
(does it work with 192k 24 bit signal or dsd for instance?
Hi there
Unfortunately I cannot answer your questions on this - I do not have this information.
At current I cannot send an escalation to Sony from this thread (as its not working!) - however I will pass on your questions to my contacts within Sony for assistance.
ProJules
Please escalate
ProJules
Here are some tests I did today
Equipment list
(hardware)
iPhone 7 plus
Chromecast Audio
Optical cable
Analog cable
Sony HT-NT5 Soundbar surround system
(software)
Google Home app - with Chromecast Audio configured
Qobuz app - with sublime HiRes subscription
Note: for all tests the volume setting on the Qobuz app was at maximum)
Casting from iphone running Qobuz app set to stream 44.1k 16bit - optical out - to Sony HT-NT5 optical input - WORKS OK (plays multichannel / surround 5.1 audio)
Casting from iphone running Qobuz app set to stream 96k 24bit - optical out - to Sony HT-NT5 optical input -  DOESN'T WORK / SILENT
Casting from iphone running Qobuz app set to 44.1k 16bit - analog out - to Sony HT-NT5  analog input  - WORKS OK (plays stereo audio)
Casting from iphone running Qobuz app set to 96k 24bit - analog out - to Sony HT-NT5  analog input  - WORKS OK (plays stereo audio)
Alternate system check
Sony SRS - XB2 speaker (analog in) As above signal out from the the CCA to the analog ins worked when Qobuz was set to 44.1k and 96k)
I don't have another system that accepts optical in to test on.
So the problem is the optical 96k 24bit signal path
