Is it possible to control HT-CT260 with samsung remote
mugzze
Wondering if it the soundbar can be controlled with the newer Samsung smart remote.  The soundbar is a bluetooth connection and it is paired with the TV.   If I use the sony soundbar remote I can control the volume.   However nothing happens with the Samsung remote.   In order to program the remote to the device the samsung menu leads to a universal remote setting.   It then allows to choose a home theater device option, yet when it asks for an input there is no selection for bluetooth, only wired connections.   At that point Im at a dead end.   Is the sony device capable of having its volume controlled by this Samsung remote on a bluetooth connection?  Or is this a limitation with Samsung?
Sean_Mc
Moderator
Hi there,
Let me look into this and I will update the thread when I have an answer for you.
Best wishes,
Sean Mc
Vanilla_
Hi mugzze,
As far as I know, It's not completely possible to control Sony devices using different remote controls.
Regards,
Vanilla_
