Linksys wireless g adapter and BDV-F500
profile.country.el_GR.title
Snoopu
I just tried to get internet by connecting my linksys wireless usb adapter to my BDV F 500 and had no result.
Does anyone no if there is a possibility to use this adapter to my home theater?
Catmambo
No, it only works with Sony wireless Dongle or you can use Home Plugs or Ethernet cable instead depending on your individual setup.
Catmambo
