mp-CL1
mp-CL1
sony mp-CL1 at first it will not turn on but after I connected to the charger, The power lamp (white) and charge lamp (orange) solid at the same time, and it did not trun off also if it is connected to the charge or not.
Pascale_F
Moderator
Hi iamaphantom,
Welcome to the community.
This sounds frustrating - I'll see if I can track down an answer for you. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi iamaphantom
Have you tried resetting the projector to factory settings? I found the steps in the Manual (Under setup): https://www.sony-mea.com/electronics/support/res/manuals/C966/ea7fd42a81d7ef8006215f29aae8a5f2/C9661...
I didn't find the model on the UK website, did you buy it from a different country?
Win_88
Sonyvores
Light White & orange means two things
1) it's damanged inside=> you need to contact Sony support to fix it
2) Battery security lock. if you haven't used the projector for a long time it has a locking security to avoid damaging the projector that prevents the projector to be turned on.
To unlock plug power , press power button and hold it. As soon you see white+ orange light on, unplug the power then re-plug right away. ( you can try a few times) If done properly, only white light will blink and yoru projector will be back to normal status and work
