nigenorris seeks help on new BDPS-790
sugoo77
Happy purchaser of this BDPS-790 Apart from apparent limit of rewind tv main channels of BBCiplayer.
From expert reviews believed would come with ITV player etc.  Tried to view via web browser but Adobe update download required not recognised by Sony.Please -am I missing something?
Bravia55HX
have you performed an update on the machine since purchase, if not then do that, also ignore the flash player thing as the sony platform does not support flash player, you should still be able to view content anyway.
Catmambo
As above, then just press the SEN button on the remote control and it will load up the UI where you can select iPlayer.
sugoo77
Thanks. I had got updated and am able to get BBC I Player and Demand 5.  But 4Seven and ITV player are not among the Apps sadly. Any likelyhood that will change?
