The unit will not restart playback from the last stopped position.
This ocurrs even though the unit has not been; turned off, the drawer opened,other content played and USB is never used. Any ideas before it is sent back as useless?
Solved! Go to Solution.
That is "normal" for some DVD and especially BR, because some disc forbid the player to playback where you stop. It is Editor's fault, and your BR player is just doing fine 😃 They want you to watch and rewatch the preview and warning messages....
Next time just press the menu button if you know u won't go away for too long ^^
