Probleme vizionare youtube cu BDP-S3700
profile.country.RO.title
calcris54
Neues Mitglied
Cand aleg YouTube din aplicatiile disponibile, ***** intrarea in aplicatie apare un mesaj ca aplicatia este prea mare si accesul se va intrerupe. ***** acest mesaj sistemul revine in meniul principal, cu toate aplicatiile disponibile. Ieri am urmarit un film pe YouTube, dar azi nu mai pot intra in aplicatie. Poate cineva sa imi sugereze o rezolvare, pentru a folosi YouTube prin BDP? Multumesc.
3 ANTWORTEN 3
Pascale_F
Moderator
Hi calcris54,
Are you able to post this in English?
Thanks,
Pascale
calcris54
Neues Mitglied
I cannot watch youtube, because after I access YouTube, a warning message
appears saying the application is too large, then close.
calcris54
Neues Mitglied
In the main menu, I chose the YouTube application, but after entering the application a message informs me that the application is too big and will close. I changed the wireless connection (LAN) to wireless and I pressed the WPS button on the router. After these changes, I was able to use the YouTube application via blu ray. I was also able to access YouTube via wire (LAN). Problem has been solved. Thank you.
