Since buying the S590 I downloaded the latest firmware update. Since then I have not been able to play any avi file through the DLNA client as the BD player says the file is either corrupt or unsupported. It worked perfectly well before the update. Can I revert back to the original settings and take this firmware off ? Or is there another method to get this working again ? The purpose of buying the player was for this facility.
try doing a factory reset, it may have a small glitch that needs clearing.
