Hello
I have just retuned my RDR-HXD710 Recorder as it's Digital Switchover Day. I have now lost all my programme information on the EPG display and can't find a way of getting it back. It's annoying because I can't automatically record programmes any more. Any ideas anyone?
Solved! Go to Solution.
Hi blues_brothers,
which EPG are you using? If it is the Guideplus one I'm sorry to inform you that it is no longer supported. Otherwise it should work exatcly as before.
