RDR HXD870 parental lock cannot be removed after retune
890737va
Forced to do a retune today - now the parental lock password request appears after every operation. The menu option to turn it off is not available, just the option to change the password. How do I get rid of it - its driving me mad
890737va
Thanks for that. Had already tried the reset with no joy. Have now found that in channel options all channels had LOCK selected (not by me). Remove the LOCK s and problem is cured. Weird!!
Thanks again.
Marino.Manolo
Genius
Look at Page 144 / 145, or Pag. 158 for Recorder reset:
https://www.sony.com/electronics/support/res/manuals/3113/31137601M.pdf
890737va
Thanks again.
