rdr-hxd970 remote resetting
trredma
 Hi
I have 2 of these great machines and mistakenly changed the command mode on one to 3 (default). The other one has the same command mode and is working okay. I am not now able to make any changes to set up as they all seem to rely on the remote working. Is there a way of changing settings using the front panel of the dvd recorder itself so that I can then set up the remote again
Many thanks
Trevor
trredma
I've managed to sort out the problem fortunately by using both remortes and changing their command mode settings
Many thanks
trredma
Many thanks
