RDR-HXD995 Factory Reset
hcalloway
Hi.
Surprised I couldn't find an answer to this in the manual ... but if I do a factory reset will the content on the hard disk be erased?
H
Convergence
Hi A reset will only reload the default menu and tuning settings, the recordings will not be touched
Convergence
hcalloway
Thanks for your help. H
