keith-the-carver
RDR HXD995
I can only record TV manually as the EPG now refuses to work. Screen shows message ' This function cannot be used now' Why is this? Help please....
rooobb
Do you know what the recorder is doing while you get this message?. In order to fill the EPG listing in freeview mode (not the Guideplus that in any case is not working any more) the recorder must have exclusive access to the tuner. So, if for example, the recorder is recording a program you cannot access the EPG. Do you get the sam emessage if you push the "Info" button?
