I have à RDR-DC105 and I would like to record a program for example starting on january 10th at 23h30 and ending on january 11th at 0h30.
This is only one hour in total, but the recorder (timer or guide mode) does not accept that when I am in digital reception. If reception is via L1 this is possible.
Do you have a solution to overcome this problem, apart of course having 2 record sequences one on each day.
For your information, my software version is 1.05
I don't have the same recorder (mine is RDR HXD870), but there should be no problem since normally it ask for date/time to start and how long (so you don't have to tell in which day/time to stop). Moreover in your recorder you should be able to use the Guideplus and there you only select the program to record and all the information are filled automatically
My recorder does not allow to give a period for record.
But anyway now the problem has been solved by an update sent by Sony. This is not surprising because in fact this function was working at least one year ago.
Many thanks for your reply and have a good day
