S-AIR Pairing problem?
mrlad1
Appreciate any help/guidance.
I recently bought a Blue-Ray player and hooked it to 5.1 Home Entertainment System with wireless rear speakers. The wireless rear-speakers are connected to an amplifier (TA-SA200WR) with the two S-AIR transreceivers connected to both the amplifier and blue-ray unit unit.
I've followed all instructions carefully but somehow i just cannot pair the rear-amp+speakers to the main-unit. I've switched off wifi, tried different IDs but in vain. Sony support has not been useful.
Anyone come across this kind of issue and have any suggestions.
Many thanks
kbrooks2
I had the same problem.
Two options available: -
1. Upgrade your HDMI cable.
2. Wrap tin foil around your existing HDMI cable.  (Starting from the middle and finishing at the end which is connected to the Sony kit).
I hope this helps.
