Have setup and am using the Sony N100 Media player, and so far all seems well except when using the BBC iPlayer.
For nearly all SD/HD streams I get the message, normally towards the end of the programme that it is "Loading". When this happens, it then takes about 4- 5 mins before it loads enough data for the stream to continue.
My ISP is BE, and I have a connection download speed of 10MB.
I've reset the N100, to have only a wired configuration active and have the latest available firmware installed
Anyone aware of any action I can perform to improve the streaming?
Thanks and happy New Year!
Message was edited by: skaterbuoy
Hi - Just wondering if anyone is able to throw any light on this problem? I have the same issue with streaming speed and can't find any advice on how to correct it.
I've had my SMP-N100 for a couple of months now - at first everything was fine but over the last 2-3 weeks the streaming speed has deteriorated so now can only get the first 10-12 minutes of any program. As for skaterbuoy my download speed is a little over 10MB and I don't have any problems with laptop or tablet streaming.
Please help!
Thanks in advance
