SMP-N200 DLNA playback compatibility
JMX123
I have just purchased an SMP-N200 product to stream DLNA content from a Panasonic DMR-BWT800 recorder expecting it to behave in the same way as the Sony Bravia TV (KDL24EX320W) but it will not stream to the N200 device. It gives an error about it being unsupported content.
Does anyone know if this can be fixed to work like the Bravia?
Many thanks.
Catmambo
Hi
I guess it depends what content you are trying to stream from the Pana - it maybe that its locked to the device which would explain the message...
JMX123
Just trying to playback recorded TV
It is not locked as it will stream to other devices correctly.
Looks like a limit on the SMP-N200 to me.
Thanks.
JMX123
It will play MPEG recordings but not M2TS recordings
I hope someone can suggest an answer
Many thanks
