Hi i bought a sony BDP=185 bluray player about a month ago,and i seem to struggle to get it to play certain blurays.
The bluray starts to play,then gets to the language selection & freezes!!! The whole machine will not react to the remote or buttons on the player. I end up having to switch the bluray player off at the socket to eject the disc.
HELP PLEASE!!!!
as you have only had the player a short while, have you connected it to the internet and performed an update?, this is likely to solve the problem unless theres some other hardware fault, try this first.
Hi thx for your reply,and yes all software up to date
I've had the same issue. Someone has posted a workaround on Youtube:
http://www.youtube.com/watch?v=QIEXFvVXnKE&list=FLZhzxi4TYvYxNJKkgR_-QbA&index=1&feature=plpp_video
Hardly ideal but at least there's a way to play them.
Any comment from you Sony guys??
