just purchased a BDV-E3100 home cinema system. the sound echoes /reverberates badly any advice on how to stop it welcome. Its driving me bonkers!
Solved! Go to Solution.
Hi there
It sounds like you havent set the speaker distances and levels correctly. See page 41 and 42 or the manual HERE.
Hi there
Thanks for posting back, glad you've managed to solve it
