hi
the new sony bdv n7100 home cinema system is really nice, i really like the blu ray player but its a 5.1 system,
does anyone know if sony plan to realease a 2.1 system or if they are releasing the blu ray player on its own as i really want the blu ray player but not all the speakers as i have not got much room to put them all in.
thanks
Hi there
Have you considered the following two 2.1 Bluray Sytems?
http://www.sony.co.uk/product/hch-systems-with-blu-ray-disc/bdv-nf720
http://www.sony.co.uk/product/hch-systems-with-blu-ray-disc/bdv-ef220
Altertatively, you could just purchase a Bluray player and if you want speakers, have you considered a soundbar instead?
http://www.sony.co.uk/hub/blu-ray-disc-player
http://www.sony.co.uk/hub/home-cinema-systems/range/soundbars
Although if you really want that design bluray player, you dont have to connect the rear speakers (even though they are wireless), you can have it set as a 2.1 channel system. Look at page 61 of the manual : HERE and it explains how to do so.
hi
thanks for the info, i do like the nf720 but the player for the n7100 is really nice, if it does a 2.1 then thats fantastic.
thanks for the help
According to the manual, you can turn on sound effect mode and set it as 2ch Stereo
