Sony HT A7000
Rainey9
Sony HT A7000
This soundbar allows you to add on wireless rear speaker.  Are the number of add on speakers limited , for example can I add two sets of rear speakers to give more sound from the rear rather than the usual one set?
thank you
royabrown2
Hero
@Rainey9
This soundbar pairs with the rears, so I doubt if it would pair twice at once.
But do you know that one pair of rears won’t be loud enough?
If you don’t like the volume the auto setup chooses for them, you can turn them up further from the remote.
And me, if I had extra money to spend here, it would go on the optional sub first.
HannahEd01
Community Team
Hi Rainey9,  as per the illustration in the manual you should be able to add one sup-woofer and 2 rear speakers / however the connection method is to be followed from the manual of those external devices.
daniel-kutscher
I also don't think it's possible to connect 2 pairs of rear speakers. But it would be great if you could connect 2 subwoofers. I have one SA-SW5 in a large living room, a second one would add more bass punch and fun.
Maybe that could be delivered with a software update. I don't think this feature would be difficult to implement.
