Solved! Go to Solution.
Thanks a lot for the help.
Don't you by any chance know how to stop the soundbar going mute every time there's a short silence in the audio source? Makes playing Resident Evil Remake impossible.
Hey any luck on finding what is wrong with my circuit boards?
Hey,
I'm having the exact same problem as you: CT260H Sound bar will not turn on at all. Took it apart and looked for bulging capacitors but no luck. Did you ever figure out what was wrong with your sound bar?
Man that sucks. No I couldn’t figure it out. And after more research I couldn’t find any answers. Wish I knew what to do with it.
Yeah, probably more trouble than it's worth to fix. Since I'm getting absolutely no power, my first guess would be the fuse (3.15A 250v small retangle near the AC connection). I'll try to replace that if I ever get really bored. I'll let you know what happens.
Hi, I get the same while watching, Tin Star and Berlin station.
I have to rewind a little bit and then hope it plays through. It normally
works. I am pleased to know the reason it happens. Thank you.
Regards.
Derbywinner.
Thank you so much! Came across this when searching for a solution to my failed sound bar. Even though I had to buy a soldering iron, soldier and the capacitor it still only cost me £13 to fix! Compared to the cost of a new sound bar that’s a bargain! Really appreciate the advice!
Hello Guys,
Maybe one of you can help me with my HT-CT60 current problem. A couple of months ago I had the issue with the buldged capacitor and the 2 second power on and than power off. Changed the capacitor with a new one and it was a great success. Now after 2 months I have a new problem, this time I dont have any output sound from my soundbar. Everything works fine exept no output sound, regardless of the input. The remote and the power works and changes mods as it should. I tried to find a shematic/ diagram/ service manual on the web but no success. Did some of you experienced this problem and find out a solution? Do any of you have service manual where I can trace the voltages on the board to find a failing component? Thank you!
