STD 1080 - input changes constantly. Missing Software License Information
profile.country.IE.title
cornelius1
Hi, I have a problem like lots of other owners- the receiver switches to the home screen.
But now I've another one. When I'm in the 'Home' menue, 'Watch'  and want to select one of the inputs, the display flashes constantly from one input to another (e.g. from TV to Blue Ray) . Very quickly, and I can't select any of them. It works after re-starting (most of the time)
Since I think there might be a software problem, I went to System Settings, Software License Information. There were no information in there. Anybody similar issues
Tags (1)
Sean_Mc
Moderator
Hi Cornelius,
It might be best to get in touch with the support team for further assistance with your issue here.
Best wishes,
Sean Mc
cornelius1
Thank you. Already contacted support. They send me the link for the manual. Useless as usual
Vanilla_
Hi cornelius1,
I assume you're referring to Sony STR-DN1080. I've actually found a recent firmware update released by Sony. You can check if this can solve the problem. Here's the direct link for the update: https://www.sony.co.uk/electronics/support/audio-components-receivers-amplifiers/str-dn1080/download...
Vanilla_
