Hi all
can any body answer the question please
is my Sony STR DH 810 compatible with DSD i had a sony blu-ray which can play my SA-CD collection which i cannot get multi channel through my amp
i can find a small reference to DSD in the manual which doesn,t make any sense to me,
i am not the brainiest of people mind.........any help appreciated
even the richer sounds and 7 oaks are lost with my quetsion
Message was edited by: waz123
unfortunately, your amp doesn't support DSD signals
ClarkLong
Thank you for your reply :smileycool:, it is wierd that sony produce many Blu-ray players capable of playing SA-CD over HDMI in DSD yet i struggle to find a amp with DSD in the specs.
i have emailed sony and yet 5 days later have not recieved a reply:smileysad:
the 820 has replaced the 810 yet i cannot find DSD on its spec sheet
would any one know if the 820 is capable of DSD
The other optuion i have looked at is replacing my Sony with a Cambridge Audio which has 7.1 anologue connect, how ever i would like to keep to Sony if possible
The 820 doesn't support DSD either...
What's ur SACD player? Might be helpfum to find out a solution
