Has anyone managed to worked out the SONY code for a BT Vision+ Black Box so I can at least power on/off from the SONY AV remote controller ?. There was a suggestion the BT Vision Box was made by Motorola but their codes don't work... Not sure if a BT Vision Box would be classified under satellite or cable since its part Freeview part Internet
I've discovered the BT Vision BOX is a PACE DiT7831/05_2B.
Trying all the PACE codes for a satellite tuner (848,849,850,852,862,863,864) on the Sony Remote controller, only 852 seems to be recognised by the BT Vision IR and causes it to flash. However none of the functions operate...eg. power on/off,numbers(0-9),up/down.
Please could someone from SONY investigate the problem ... Thank you
