STR-DN1080 low Bluetooth volume
h10d2d
Hello
I am running my turntable through av receiver str-dn1080 and listening via a pair of wf-1000x but problem I have is that the volume is not loud enough and can't be adjusted via the av amp volume control.
I did a software update and it cleared the problem until I turned av off. The next time it was turned on it was back to the low volume again.
any ideas?
Marino.Manolo
Genius
Does not change anything if you adjust the volume before connecting the Bluetooth headset?
Manolo
h10d2d
Thanks for reply
No makes no difference
Sent from my iPad
