Hi all.
I have a SVR-HDT500 hard-drive connected to my TV via HDMI cable. The unit can be connected to internet via LAN cable socket (RJ45?) however due to location this isn't possible for me. Is it possible to connect a wireless adapter/dongle to this port to access my home WiFi remotely? If so, what type/spec should I be looking for?
Many thanks in advance.
Neil
Message was edited by: neil.skinner
Solved! Go to Solution.
Hi Neil,
The manual says the network connection is for future expansion. It doesn't look like there are any Network capabilities available at present - so no point connecting.
http://pdf.crse.com/manuals/4265096131.pdf
Hi Neil,
Thanks for your help. Neil
