Take the HBD E370 abroad
massimek
Hello,
I would like to take my HBD-E370 to Italy, currently I live in the UK.
Can anyone advise what will happen to the internet content currently available with this system, for example lovefilm or Iplayer which  are services not available in Italy?
If these services cannot be accessed is there a way to upgrade the firmware to include content available in Italy?
Thanks!
Catmambo
Hi
Basically the services are geo-filtered by the content rights holders  and so once your IP address changes as it would if you change countries, you would no longer be able to see any of the UK services and the device would simply display Italian content instead.
Catmambo
Hi
