Nfparkinson
Time display
How do you remove the time display from the bottom right of the screen  it only appears when hdrx890 is in use is it tv setting or recorder setting ?
Cheers  neil
rooobb
it has nothing to do with you recorder setting, it's your TV that displays the time information on external input. If it is a sony tv just press the info button once and it will disapper.
rooobb
Nfparkinson
You diamond! Just one of those annoying things that when you get home you find your missus has let the kids at the remote then she has had a go at doing something and then your left with a setting that just baffles you ! Thankyou
rooobb
I'm really happy that such a small thing make you happy :slight_smile:
