Two remotes with only one signal
pegraft
I have just bought a BDPS390 to complement my existing BDP S300, trouble is either remote will operate both players. Is there a way of changing the signal on either remote so that each remote will operate only one player?
Bravia55HX
other than putting one of the players in another room, no.
Thalamus.
Champion
Hi pegraft,
no unfortunately you can not ammend the remote signals, best option I can think of is to switch of the power to the BD player that you do not wish to use, not ideal though..
