UBP-X800 and UBP-X800M2
profile.country.NO.title
AudunSt
I have first and seconf model of the UBP-X800 and have an issue with both:  if I shut down the player while a disk is paused, it doesn't remember where I was in the movie when I turn on the machine again.
I have had other brands earlier, and they even remembered what I was watching even if I ejected the disk and played another movie.
Any tricks/ hints/ settings I could try?
Thanks!
Tags (2)
IamNic
Hello @AudunSt,
but that is probably from the troubleshooting/issues part of the manual.
To me it says "if the resume function doesn't work" (confirming it is a feature like I described above) it can have these reasons.
So simply try to press "Stop" on the remote before switching the player off. It remembers multiple movies as well, but I can't give you the number of movies.
- Nic
6 REPLIES 6
AudunSt
Found it deep in the manual:  these units doesn't have this feature.  There should be space in the settings memory, but Sony have not found it important enough.  Odd, as a small 30£ player from grosery store did have this feature.
jumpsuit
Thanks for letting us know the answer @AudunSt  👍
IamNic
Hi @AudunSt,
where in the manual did you read that? I'm asking, as it (I use the UBP-X800) is definetly a feature, but for some discs, you have to press "Stop" before shutting the player off.
I can resume 98% of the movies in my collection (I have around 200 Blu-Rays, mixed between 160 HD and 40 UHD Blu-Rays, so I have quiet the sample-size).
- Nic
AudunSt
approx page 30 in the Norwegian manual I found "Playback does not start from the resume point where you last stopped playback. The resume point may have been removed from memory, depending on the disc when you open the disc tray. disconnect the USB device. you're playing other content. you turn off the player." This is a Q&D translation by me...
IamNic
Hello @AudunSt,
- Nic
AudunSt
Usually, I put the film on hold before I shut down the player - stop film do really kick of the resume function.
