Hello all!, I have an old surround sound system and the picture quality is not up to modern standards, can I buy a blue ray or upscalling dvd player and connect it to my existing system and have better vision and keep the great sound?Or can I buy a new central unit and replace the old one? My unit is SONY DAV-SR4W, yours tony
Message was edited by: teepee
Hi
Couple of different ways of appraoching this depending on budgets and how much you use your system.
Its impossible to buy the central unit as a standalone (unless someone is selling one second hand). If you are after a simple, good value, great sounding solution then number 1 is probably the best option - Sony options http://www.sony.co.uk/hub/home-cinema-systems/range/all-in-one#/1237484927716/1237484927700
If you are after something more flexible (allowing you to replace elements individually) even better sounding, then number 2 is the way to go I think. Starting with a good receiver - http://www.sony.co.uk/hub/home-cinema-systems/range/2 and Blu-ray player - http://www.sony.co.uk/hub/blu-ray-disc-player
Hope this helps
that would depend on the Amp you select on whether you can use your sub or not as most subs that come in a kit are passive, and for separate Amps you would need an Active one.
