Upgrading home theatre system to Blu-Ray
NortholtB
I currently have a DAV-DZ260 home theatre system. I would like to move up to Blu-Ray. Would I have to replace the whole system, or could I just replace the DVD player? If  the latter, which model is recommended?
profile.country.FR.title
ClarkLong
Since your DAV has an optical and coaxial digital in, you can just buy a Bluray player and use the optical/coaxial out of the player to connect to your curent DAV that will be used as an amp.
The only downside is that you won't be able to enjoy the HD tracks for that but just regular Dolby 5.1 and dts. For HD audio, you'll need to buy a whole new system.
