USB Keyboard
kisa01
USB Keyboard
Can someone advise if it is possible to plug a usb keyboard into the RDR HX870 or similar DVD recorders to enable title editing rather than doing it via the remote?
Sputnik_2
Kisa01
Having read the manual for the RDR-HXD870 it looks as though there is no firmware handler for a keyboard on this unit.  The USB-A port is specifically configured for memory devices and cameras.
I don't know if it will help but have a look at my keyboard item in the listings.  I tried until I got a unit that didn't cause my player to complain about compatibility and then proceeded to test it for performance.  If you have a 101-key keyboard give it a go!
Sputnik_2
Message was edited by: Sputnik_2
