The message you are trying to access is permanently deleted.
I'm really pleased with my Sony TV and can easily access my Panasonic HDD (DMR-EX77) using the 'Inputs' button on the remote. To make recording even simpler is there a way to set the Panasonic to record from the Sony, i.e from the Sony TV Guide selecting the program I want and then using 'Options > Timer Record > Set Timer as a Series'.
I never tried myself and I don't know which Sony TV do you have, but with my own KDL32W4000 this is possible only via Smartlink connection (via SCART cable). In my opinion, I wouldn't exchange the upscaling via HDMI just to use the guide of the Tv, but I've a Sony RDR HXD connected via Braviasync to the TV (so I don't even have to push the input button to access the recorder, just switch it on and press play).
The other problem that I see, is that if you program a timer via the TV, the input for the recorder will be the TV tuner itself, so you loose the ability to watch another program while recording
Thanks Rooobb. I'll give it a try tonight. For the record the TV is a KDL32EX653 .
