VHS to DVD deck shows interface over video!?
dansleeth
I have a Sony VHS to DVD deck RDR-VX420, which is connected to my computer via a Canopus box (which converts the RCA to Firewire).
When I record a VHS either to DVD or onto the computer, every so often the deck will randomly display a message over the video.  This makes the unit pretty useless, as I do not want my home videos forever tarnished with that message.  How do I remove or prevent that message popping up?  I have looked through the menus and manual, but nothing mentions it!  Is this just an aweful design flaw?  I am 100% sure that it has nothing to do with the canopus box, as it is passive.
[ VIDEO ]    [ SP Hi-Fi  Prog. 3 ]
I have attached a screenshot example of what pops up:
Any help would be appreciated!
Daniel
StartTheCar
I dont have an instruction manual for this unit to hand, but it looks like you have turned on the display info on the RDR-VX420.  To be honest I didnt think this would then transfer over but thats what it looks like.
On the remote there is probably a 'display' button which will hopefully hide the information and stop it from being transferred to your PC.
Hope this helps
Lee
