Will my six speaker system plug into the Blue Ray Players?
Paddynev
Dear All
We have lost the DVD Player (during our recent move beack to theUK)  for the pictured speakers and wonder if we can use them in conjunction with a  BDP-S390  Blue Ray player?
Regards
Paddy
profile.country.FR.title
ClarkLong
Actually, you can still keep those speakers and buy an amp + a sub (because yours is passive so it won't work with regular amp). And invest later on for better speakers. Unless you can afford to get a whole new set :slight_smile:
4 REPLIES 4
ClarkLong
HI there,
no the S390 is just a BDplayer, it doens't have 5.1ch amp for you to connect your speakers to.
Paddynev
Thank you very much.
Which player sould I purchsse that would use these speakers?
Kind regrds,
Norman
Bravia55HX
there is no player available other than the unit you lost that will accept these speakers im afraid, you'll do well to lose them as well and start again perhaps with a dedicated system, or build your own home cinema system with new speakers and separate amp.
ClarkLong
