x700 stops playing 4k discs
karingall
My x700 stops playing 4k discs while watching the Equaliser it stopped playing at 1 hour 35 mins, also playing Captain Marvel it stoped playing after 2 hours 10 mins in both cases could not fast forward or get them to move on noted the time by the display button, this problem has happened in the past on other films but 2 in 2 days??
Lucky to have my old x800 no problem with this player at least I know the discs are ok
Any one else had this problem and is there a way of solving it
karingall
Hi WIN88
Thanks for the info
Have done a factory reset we now seem to be ok
The player did freeze
Will leave this open for a while just to make sure all is ok
I have a new problem see Lost home screen on x700
Thanks again for the help
Regards Richard
4 REPLIES 4
EdwinaU
Moderator
Hi Karingall,
Can you tell us the full model number of your product?  We can then look for some advice for you.
Best wishes,
Ed
karingall
Hi Ed
the model of the player UBP-X700 serial no 2003148 look forward to receiving some advice and help
Regards
Richard
Win_88
Specialist
Hi Karingall
There are a few things you can try:
1- Update the player: https://www.sony.co.uk/electronics/support/home-video-blu-ray-disc-players-recorders/ubp-x700/downlo...
2-Try resetting the player:
  1. On the supplied remote control, press the HOME button.
  2. Select Setup.
  3. Select Resetting.
  4. Select Reset to Factory Default Settings.
  5. Select All Settings.
If this doesn't fix it, let us know more about the issue, like does the player freeze during playback or does it crash? Do you notice any issues while playing different type of discs or content from any of the installed apps?
Win_88
karingall
Hi WIN88
Thanks for the info
Regards Richard
