Turn your BRAVIA TV into your home entertainment hub Home Theatre Control lets you control the audio settings on your home theatre system from your TV – with just one BRAVIA TV remote*. It turns your TV into a home entertainment hub, enabling you to adjust and fine-tune the settings on a connected Home cinema system via an easy to use on-screen display. |
How to use Home Theatre Control When activated, the Home Theatre Control application is displayed on your TV screen. From there you can control the Sound Field, Input and Sound settings of your home theatre system via your BRAVIA TV remote control. As long as the device you want to control is connected to your TV via HDMI®, you won’t need to use any other remote controls.
Tip
You can also use the RED colour button as a shortcut key to power off the home theatre system. |
Setting up Home Theatre Control When you connect your internet-enabled BRAVIA TV to the internet, |
*Internet connection is in needed to use this application.
“Control for HDMI” setting should be ON for both “BRAVIA” and Home
Theatre System.
Applicable models
[Home theatre system] RHT-G15/RHT-G11/RHT-G5/HT-CT350/HT-AS5/
HT-AF5/HT-SS370/HT-SF470 [TV] LX9 series, NX8 series, NX7 series,
HX9 series, HX8 series, HX7 series, EX7 series, EX5 series, EX40B series
You must be a registered user to add a comment here. If you've already registered, please log in. If you haven't registered yet, please register and log in.
