LED TV vs LCD TV - What's the difference?
jaylward
4,212  Views
Read LED TV reviews and you might be left wondering what the difference between an LED TV and an LCD TV is. Confusingly they both use LCD screens – the different names refer to the different ways in which light is used to generate the picture.
The term LED simply refers to one of the methods that manufacturers use to supply light to the back of an LCD screen.
LED TV and LCD TV compared
Conventional LCD TV
LCD TV with LED technology
Screen type
LCD
LCD
Backlight technology
CCFL technology
Cold Cathode Flourescent Lamps spread a white light across the back of the LCD which is then coloured to generate the image.
LED technology
Light Emitting Diodes (LEDs) emit a coloured light using less energy and space than traditional bulbs.
When used to backlight an LCD they may be white lights or they may be used in sets of red, green and blue (RGB LED)
LED TV technology brings powerful benefits in terms of slimness and picture quality. LCD TVs are rapidly developing to offer different strengths. The simple guide below should help you understand the strengths of these two technologies:
LED – opening up new possibilities
There are two types of LED lighting - LED Backlight and Edge LED:
LED Backlight is positioned behind the screen, and each group of lights can be locally dimmed. This helps the LCD deliver deeper colours, higher contrast and a greater range of shades in the all-important dark end of the spectrum.
Edge LED places white LEDs around the edge of the screen, which clears the way for screens less than 1 cm thick.
Edge LED   LED backlight
How does it work?
LEDs are placed around the edges of the TV and the light is distributed evenly across the screen using light guidance plates.
Key benefit
Avoids the need for lights behind the screen.
Result
Incredibly slim TV. The BRAVIA ZX1 is only 9.9mm thick.
pic1a.jpg How does it work?
LED lights are placed behind the screen. With local dimming they are organised into groups and the brightness of these groups of LEDs is controlled separately.
Key benefit
Produces richer, purer blacks and delivers more realistic colours to the LCD screen.
Result
LCD can deliver incredible colour accuracy and improved contrast especially for darker colours.
LCD – packed with innovations
As an established technology, LCD is now being refined and improved. This stream of innovations includes features that add incredible detail to action scenes, ways to improve colour accuracy and improvements that reduce energy consumption.
LCD technology allows a brighter picture so LCD TVs are watchable in all situations and circumstances. Kitchens and workplaces are now suitable environments.
BRAVIA ENGINE 3 offers reduced noise levels and improved colour and contrast.
Motionflow 200Hz. This innovation works out the path of movement in a scene and produces extra frames to smooth the flow of action and reduce judder.
New HCFL backlighting reduces power consumption and your energy costs by 50% compared to previous LCD TVs of the same size.
Explore the BRAVIA TV range
At Sony we’ve spent more than 60 years making picture and sound clearer, sharper and more lifelike. And with the advancements in picture quality, connectivity and 3D in our latest LCD and flat panel TVs, you can see just how real a picture can get.
