How to turn off screen during Viber calls?
Essharnouby
Hi,,
I have the following problem with my Xperia L (2105). The screen stays on during Viber calls. It's as if the proximity sensor does not work, but it works just fine during regular calls and facebook calls. The only way to turn the screen off is with the power button. Is there a know fix for this issue?.
Thank You...
Essharnouby
Thnx for answer bro
Shravan_sp
No it depends on viber. They must update viber to support the proximity sensor to turn off display automatically.
Like in regular calls and Facebook calls, they use the proximity sensor, so when you bring it up to your ears, the proximity sensor detects it and turns off the screen. Whereas in viber, it does not use the sensor i guess.
Essharnouby
Thnx for answer bro
