Remove Bloatware
Racso886
Remove Bloatware
Hi, i from Colombia so i don't speak (in this case write) English very well
I just bought my Xperia L1 directly with the Phone Operator, but they pre-install some apps from their own and others app like games, but i cannot remove it only disable it, but if i look the memeory when my device of 16 Gb is new there are 8 Gb fill!!! that is the half memory full
So, my question is: If i will use PC companyon to repair the software the bloatware from my local Phone Operator go away?
(Yes, i know that i will know if i'll do, but i want to know before to do it)
Uliwooly
@Racso886
it won't go away, you have couple options, either root the phone and uninstall any preloaded apps, or flash the phone with xperifirm with a firmware with less bloatware.
Uliwooly
@Racso886
Racso886
Thanks for answered me
I will try your options
Uliwooly
@Racso886
anytime
