My sony's battery percentage started jumping up and down, most of the time it now stics on 50%....and every now and then it changes to the actual percentage...also stops and starts charging after it reaches 90% charge level...did hard reset but didnt change anything...
Any ideas?
Things to test, boot on >>> safe mode and see if you experience the same issue, if you don't then its a third party app acting up
if you do, you might want to repair the phone with XC
Alternatives on How to backup Xperias
