My Xperia M Dual C2004 won't turn on! A red light blinks/flashes 3 times..... Please help
garvmaggu
I switched off my phone last night. Then I switch on it. When I press and hold the power button, it vibrates but nothing displays and no respone (black screen). My battery was 95%. Then, today when I tried to switch it on, a red light flashes 3 times. I tried many times but the same problem. I charged it for 3 hours but same problem and I also tried Volume Up + Power Button but it also fails. Please help me.... Please...
33 REPLIES 33
profile.country.RO.title
_alexdon_
What does it happen when you try to repair?Charge for 1 hour and repair after.
alexdon
garvmaggu
Don't work...  Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face Slightly_frowning_Face please help.... please help....
manjuboyz
Hi garvmaggu
     explain your current status , what happened and what you did, the explanations you said appears bits of pieces , sorry not able to understand, please be clear
Manjuboyz Slightly_smiling_Face
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks Slightly_smiling_Face
garvmaggu
When I press power button, a red light flashes three times. When I press and hold the power button,  nothing happens (no vibration, nothing on screen). PC Companion is also not able to detect my phone. Update Service is also not detecting my phone. Phone doesn't go to fastboot or flashmode. Also Volume Up + Power button combination for 20 seconds failed.
garvmaggu
To alexdon,
Update service is not able to detect my phone, so I can't repair because my phone doesn't go to flashmode.
manjuboyz
Hi
try this link let us know it works or not
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
NOTE:
garvmaggu
No, don't work. By doing this, again a red light flashes three times.
alexrx
Enthusiast
@garvmaggu,
What operating system do you use?
garvmaggu
Windows XP
alexrx
Enthusiast
Windows XP with service pack 3?
