No service after replacing loudspeaker
Zh5
Hi! I have Sony xperia m4 aqua and I recently changed the Loudspeaker because it had bad sound. When i installed the new speaker and turned the phone back on the sound problem was gone, but I don't have network. It says emergency calls only and I can't call anyone or be called by anyone. Searched a lot on the web but no luck so far. Tried to manually register network from settings-mobile networks-search networks but no result.
ChloeS
Hi @Zh5
Welcome to the community!
Sorry to hear about that Slightly_frowning_Face
If the issue has occurred after you replaced the speaker in the device it is likely something could have been damaged through this process, the only thing we would suggest is contacting your Local support to have an assessment and repair arranged.
Good luck Slightly_smiling_Face
