SIM slot problem
Alias646
SIM slot problem
Want to repair my both sim slot...how much it will cost?
Jonas
Master
Hi @Alias646, sorry to hear that your device is in need of a repair. Slightly_frowning_Face
This is a Global user based forum and repair costs may differ between markets, so I would recommend that you get in touch with your Local support team and see if they can give you an estimated cost for the repair.
They will also be able to assist you with arranging a repair and answer any questions you may have regarding local service routines, warranty and so forth.
Do note that I can't give you any guarantees that they will be able to do so, since the device may have to be examined at an authorized service centre at first.
I hope that helps! Slightly_smiling_Face
