Just want to know, I have connect my M5 with a usb cable to my PC, it is charching, but it seems the PC does not pick it up. Can the problem be the cable , the M5 or the PC?
Solved! Go to Solution.
when you connect the device to the pc, try to look at your device, it will give a prompt of what you want to do. like, charge only (default) or manage files via MTP,
to make it automatically detect your device, try to dowmload XPeria companion
What if there is no prompt?
