Hello everyone,
I am new to the "Sony" Xperia range but been a long time user to the "Sony Ericsson" range.
I bought my Xperia M from the official Sony Store from Malaysia but however I have a problem.
The phone came with WhatsApp but it says the date and time is incorrect!
And yes I did all the maintenance stuff. I updated my phone to Android 4.1.2 Build version 15.1.C.1.17 and I updated the app (It updated the moment I connected it to WiFi).
I currently haven't got a SIM into this thing so do I need to put in the SIM card first before it will work or is there another problem?
Please help.
Thanks!
Solved! Go to Solution.
@uliwooly wrote:Have you installed whatsapp from the play store?
Managed to fix it by uninstalling the app and reinstalling the app via Google Play. Thanks for your help
Try this
Settings > Date & ime > try either Automatic date & time and automatic time zone
@uliwooly I tried, no luck.
@satmechy2 wrote:
go play store update whatsapp that's it 🙂
It said update on Play Store but said Invalid Download URL, but I managed to fix it by uninstalling and reinstalling the app, thanks anyway
Glad to hear that you figured it out
Its common. i had to uninstall n reinstall whatsapp on both M and recently purchased L too. same issue time and date wrong...
