Initial error
An error occurred while preparing to update your device. No changes were made on your device.
Please try again later. If the problem persists, contact Sony support.
Error code: uestartnomoreports
L_2384
Solved! Go to Solution.
hi
Please can someone assist me ,I have clicked the update button on the xperia companion i have enough memory yet i dont see any download or any pop up
I have been trying to update my M4 aqua since yesterday. Tried repairing but i get stuck at step 5 where you have to disconnect usb and reconnect while holding down volume down key. Nothing happens when i do that. I have reinstalled xperia companion, turned off my firewall and even did a factory reset on my phone. Now i have a bigger problem since attempting the system update now my phone is constantly on emergency calls only. No sim service whatsoever.
Does your PC recognize the phone at all?
So once the update has been downloaded, and the installation failed, can I find it in a folder on my PC? .... In my world 1.5 gig plus of data is a substantial amount to waste......also can't help but wonder Sony, why such a cumbersome process when on other manufacturers products you can do it in one simple step on the device?!
error message when trying to download system update 1.1gb free space
@Warmaster Exactly the same problem I am facing. I have tried updating Java, reinstalling Xperia Companion, and resetting the phone. It just won't detect the phone in that final step.
@Warmaster
I have the same issue, did you ever get this resolved?
update not come for m4 aqua
