access point names is not opening
I updated my Arc to ICS yesterday and when I navigate to settings -> wireless & networks -> mobile networks -> access point names , I get a message "Unfortunately the settings has stopped"
Also at times my internet connection drops in which case i need to do settings -> Device (Xperia) -> Internet Settings which will again download my internet settings and restores my mobile internet.
It was working perfect when I was on GB but now in ICS 4.0.4 i am getting this error... appreciate any help on this!!
Cheers!!!
gwhispererz
Champion
Hi, sugges you reflash firmware again, probably the earlier update was somehow corrupted.
4 REPLIES 4
gwhispererz
Champion
Thanks for the suggestion.. will try and update on it
Reinstalled the firmware and it works, thanks for the prompt support gwhispererz
gwhispererz
Champion
No problem ....
